Wiring multipe speakers in bags"Out of Phase"
Old 07-20-2018, 08:19 PM
marcodarq's Avatar
marcodarq
marcodarq is offline
Default Wiring multipe speakers in bags"Out of Phase"
has anyone ever dabbled or actually wired up their speakers out of phase in the bags?
i'm wondering if this would make things any better. got 6x9s in the lids and 8's firing to the inside. i wonder if i wire the 8's up out of phase with the 6x9's if it might make anything sound better. anyone ever done it?
m
Old 07-20-2018, 08:25 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Hoyt 1911A1 is offline
Is that something you had read about somewhere? I only ask because in every situation I have had speakers (or even a turntable needle) wired out of phase the end result was no bass whatsoever.
Old 07-20-2018, 08:58 PM
Moto Mike's Avatar
Moto Mike
Moto Mike is offline
I have heard that wiring woofers and subs out of phase in certain situations like sharing the same space (volume) or speakers in the rear of a van (distance to ears) is advantageous to wire out of phase. Only one way to find out for sure, easy to do..go for it!
Old 07-21-2018, 07:04 AM
Roadie13's Avatar
Roadie13
Roadie13 is offline
Received 1,005 Likes on 497 Posts
There's an older thread of someone doing it in a tourpak to make more efficient use of the limited air volume there so the concept makes sense, but I don't have anywhere near the level of knowledge needed on speaker physics to say if it would work or not in a bag with larger speakers. It did make an improvement in the tourpak thread.
Old 07-21-2018, 01:20 PM
Dsm Limited's Avatar
Dsm Limited
Dsm Limited is offline
Moderator
Received 8,166 Likes on 2,938 Posts
I am one of the people that run 1 speaker in my tp pods out of phase. I was getting better bass response with the trunk lid cracked open rather than closed. I ran the right speaker out of phase and it helped
Old 07-21-2018, 01:28 PM
MMXIWG's Avatar
MMXIWG
MMXIWG is offline
I’m doing it also based on a recommendation from tesnevo I think.
Old 07-21-2018, 02:26 PM
arlington's Avatar
arlington
arlington is offline
You can try it just make sure that all the 6x9s are reversed, sometimes sounds better sometimes you can't tell the difference. I tried it wasn't enough difference to leave them wired that way.
Aero993
Audio Systems
11-13-2015 02:46 PM
scarin
Audio Systems
02-26-2014 09:44 PM
ironglass
06-22-2009 08:43 AM
Mongo40
08-13-2008 04:54 PM
Mongo40
01-18-2008 06:49 PM
Quick Reply: Wiring multipe speakers in bags"Out of Phase"
