Need help with settings...
So I have a 2017 Road Glide special. I have been very disappointed in the audio since I got it. I am a very fast rider etc. almost always going 90+ and for long rides.
Anyway I did what i thought was lots of reading/research and finally decided to install lower fairings, a DSR1, a ss pn4.1000d amp, and four hertz hcx 165 speakers.
I read all the installation and set up info on american hard bag and some here, and never could get a good sound out of it all. Finally I decided maybe the amp was too much for those speakers as I had to have the gain on amp almost all the way down.
So I returned the hcx 165's and bought 4 x Hertz MPX mille pro 165.3 speakers. i was able to turn amp up some to about 11 o'clock but now sometimes music pauses for a second if I'm playing it loud i think amp getting hot. Plus I can't for the life of me figure out how to properly set dsr1. I have tried the pink noise file and a rta app to show me the scale so i can try to flatten the signal with the EQ on dsr1 but honestly if i do that it sounds like crap and clips even more.
Looking for help, a better explanation of how to set this stuff up right. I guess I'm just not understanding the stuff out there i have seen.
I've had the best luck with flashing the bike first then tuning the DSP. Trying to flatten a process signal just to get to flat never provides the same sound. If you want to send me your radio I'll flash it for you and send it back. Tuning the DSP will be a much easier process at that point. Those speakers should be loud enough to enjoy at speed. Probably not as loud as you'd like but definitely not to give the issues you are having now.
I have not tested them all for fade function. I played with a few for the flattest signal and rolled out with 8/2 option as the best sounding. I'll try a few here soon.
Neither will fit in the pods. You have to notch the pod a bit for one corner of magnet to poke through a bit. Oddly the cheaper speaker the hcx is deeper and requires a bigger notch.
Haze, at the end of the week, I install an RF HD14-Tkit with a DSR1. But before that the HU will be flashed (Friday). According to what I can find as information, RF recommends 2 speakers, one amp. Does 8 speakers 2 amp have the same effect on the equalizer curve? The rear speakers will be installed next summer, so I would like to make a flash that would allow me to activate everything.On the other hand, I believe that the fader option will not work with these flashes.
8/2 has the flattest signal. I used it with every install we do regardless of what the actual install is on the bike. You may not need a DSR1 if you are running coax speakers and can adjust the crossovers on the amp. I'm always a fan of using DSP and EQing each channel separately but understand there is a huge learning curve and sometimes the confusion of setting up the DSP just makes things sound worse.
My stock 6.5 boom HU is NOT flashed right now. it was a normal RG special two speakers in fairing no amp.
I bought the resistors and did this, but only the fronts left and right because i didnt have the harley plug for the rears and i didnt want to cut anything.
Thank you Haze,
With these setting (8 speaker, 2 amp or 2 speaker 1 amp) if I am right, the FADE function on the HU is lost. Therefore, I will use the trim level adjustment of the DSR1 to overcome the lost of the FADE. I don't know if it is a good strategy but I will try it . You are right about the DSP but I am use to play with that in audio. So, I feel confident about that.
Can you confirm that with this setting, the FADE function on the head unit is not working anymore. I would like to know before I will do the flash.
I think these precision are good for Morpheus as well.
Thank.
Thank.
