Getting a check engine light Iron 883
All,
I keep getting a check engine light along with an error code of P0132 on my 2017 Iron 883. This error code indicates that the front cylinder is getting to much fuel. Current mods on my Iron include FP3 tuner, V&H VO2 naked A/C & Crusher Maverick slip-ons.I thought it might be the FP3 so I called V&H and they tweaked the map and re-flashed. I was good to go this past weekend but today a few blocks down the road the check engine light and P0132 came back on. I called V&H again and they suggested that it wasn't the FP3 but maybe a O2 sensor issue and to call the dealer. I called the HD dealer and explained my situation. They said they would look at it but asked about any mods. I told them my current mods and was told the issue was probably the FP3 tuner. That said, they would look at it as long as I flashed it back to the stock map. I'm thinking about having them look at it just to see if they find anything but I'm kind of skeptical. I don't want to be given the run around.
Has anyone had a similar experience? I'm a little lost at this point. I don't feel like I should be having these issues with the mods I have. The only thing I can think of is the order in which my mods were made. Bike ran fine stock, slip-ons ran fine, FP3 added ran fine and then A/C added along with re-flashed started getting check engine light and P0132 error code.
Any advise?
Any advise?
In terms of least amount of work you could put on the stock A/C and the stock flash and just try it.
I put a FP3 on my bike and applied the flash for a stock setup. That made a noticeable difference to the fuelling. I then changed the mufflers and a/c and applied the map for that, not so different to yourself.
I thought about this. I feel like thats when the bike was running at its best. I'm assuming you haven't had any issues after adding the mufflers & A/C?
Copy.
As far as it being something upstream such as a fuel injector leak, this is the kind of thing that worries me. That might be out of my paygrade lol. I'll check out the tuner reading and go from there.
Thanks for the replies gentlemen
Received 17,598 Likes
The stock H-D Map from Vance and Hines server is not the same one that came with ur bike. The stock Map u need to flash is the slot-(0) Map in the View/Edit Map section of the Fp3 app. This is the original Harley stock Map that came with ur bike and was saved to the Fp3 when u first installed it.
Don't deep dive into specific settings such as injector duty cycle etc right now, it will only complicate things..like u said it's above ur paygrade. U need rule out one thing at a time.
To know if the Tuner/Map is the culprit. Reflash the Slot (0) Map..take the bike for a moderate drive, don't run it real hard cos it will run lean after the stock Map flash and start knocking or pinging..see if it throws the code again. Report back
