VP Aim Clutch wont fit under Derby Cover
Old 03-19-2019, 07:43 PM
pounder35's Avatar
pounder35
pounder35 is offline
Default VP Aim Clutch wont fit under Derby Cover
Am I doing something wrong . they say it will fit right under derby cover . Not mine . Derby cover won't go back on . Anyone Install one of these?
Old 03-19-2019, 08:24 PM
dawg's Avatar
dawg
dawg is offline
Received 2,969 Likes on 1,718 Posts
When I ran a VP, I had to use a derby cover spacer ring to keep my cover. https://aim-tamachi.com/collections/...asket-hardware
Old 03-19-2019, 09:17 PM
pounder35's Avatar
pounder35
. Thanks Again Dawg. Been thanking you for years. Lol
Old 03-20-2019, 04:23 AM
skydude426's Avatar
skydude426
skydude426 is offline
Some derby covers will work with the variable pressure clutch and some need the spacer to get enough clearance.
Old 03-20-2019, 05:57 AM
grbrown's Avatar
grbrown
grbrown is offline
Thumbs up
I'm sure there was something about that in the instructions I got with mine!
Old 03-20-2019, 06:15 AM
62hdbiker's Avatar
62hdbiker
62hdbiker is offline
If you go to their website- it shows which ones need a spacer
Old 03-20-2019, 07:50 AM
skydude426's Avatar
skydude426
The first derby cover I had needed the spacer. I’ve since changed derby covers so I no longer need the spacer on the bike. What I do use the spacer for is a template to mark Cometic derby cover gaskets for cutting out some of the gasket to get the clearance needed for the VPC. I also bought a small heavy duty curved scissor on eBay for cutting the gasket which is made of metal covered in gasket material.
Old 03-21-2019, 07:03 AM
pounder35's Avatar
pounder35
I'm open to changing derby covers which one you get?
Old 03-21-2019, 12:06 PM
skydude426's Avatar
skydude426
My Wife’s 2006 Ultra has a HD flames derby cover.
My 2012 Ultra has a custom derby cover from a guy no longer in business.
Both fit variable pressure clutches without spacers.
My HD variable pressure clutch came with a paper cut out template that you hold up to the back of the derby cover to check for clearance.
Im probably not much help.
Old 03-21-2019, 01:32 PM
62hdbiker's Avatar
62hdbiker
If you use a spacer- the floor board probably wont fold up
Quick Reply: VP Aim Clutch wont fit under Derby Cover
