Compression release
Compression release
Recently my cam box when out. I was doing about 85 when it went. It appears my valves closed up and my ACR for both heads either blew out or got stuck open. Is there a fix for this or do I need to fork out the cash to replace them? I’m fairly new at this and do my own work. Thanks ( pic is finished work for attention)
yea, both tensioner went out. Replaced that and crank gear on primary cam chain, bearings in support plate, and secondary cam chain. No broken or bent valves. But no compression.
Not having had a good look at ACR's, I don't think they're going to 'stick open'.
I'm betting that you do, in fact, have bent valves but perhaps not visible to the naked eye. Maybe you did get super lucky and just have it out of time so the valves aren't closed when they need to be. This is all just conjecture...
