Let us know if your HD primary vent fix has worked or failed
Old 05-15-2019, 06:06 PM
Redrodyankneck's Avatar
Redrodyankneck
Redrodyankneck is offline
Default Let us know if your HD primary vent fix has worked or failed
With all of the primary vents being installed by HD to solve the transfer issue I would be good to know who had the vent installed.
Lots of guys seem to be using the belt and suspenders approach to fixing this problem using multiple proposed fixes out there. Doing so you can't say what actually stopped the transfer.
I'm interested in Guy/Gals that have had only the HD vent installed. Problem fixed or not fixed and how many miles?
Top Answer
05-18-2019, 08:39 AM
$tonecold's Avatar
$tonecold
$tonecold is offline
Received 1,743 Likes on 933 Posts
Originally Posted by Redrodyankneck
This thread is simple, fixed or not with vent, discussion as to why is else where. I don't want this thread to get bogged down with all things that have been discussed for a long time.
So far 100% fix rate.
You probably should have made it a poll. That way they just have to vote, posting isn't necessary.
Old 05-15-2019, 06:57 PM
Red's Avatar
Red
Red is offline
The H-D inner primary vent fixed my '19 Limited. At least no transfer in the last 2,000+ miles. Before the fix it would suck the trans stick dry in a tank of fuel.
The following 2 users liked this post by Red:
2018sportglide (06-27-2019), G'day (05-24-2019)
Old 05-15-2019, 07:37 PM
jlombard's Avatar
jlombard
jlombard is offline
Count me in no transfer after the vent installed, Had this problem for 2 years.
The following 2 users liked this post by jlombard:
Old 05-15-2019, 07:43 PM
mjwebb's Avatar
mjwebb
mjwebb is offline
Received 8,543 Likes on 4,431 Posts
how long has this vent been out? wonder if long enough to incorporate into the 2020 design / release..although I have a difficult time they would make this fix as OEM due to the appearance of it? maybe they will have implemented a more discreet venting solution
Old 05-15-2019, 07:50 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,922 Likes on 17,475 Posts
My question is why is it a sealed system that worked just fine through 2 engine designs and 2 trans upgrades all of a sudden has to be vented? Sure sounds like a band-aid approach to a hardware problem.
The following 7 users liked this post by TwiZted Biker:
2018sportglide (06-27-2019), Goose_NC (12-27-2022), hattitude (05-16-2019), Mountainkowboy (05-26-2019), QNman (06-21-2019), Silentgreyfellow (05-16-2019), tbob (05-16-2019) and 2 others liked this post. (Show less...)
Old 05-17-2019, 07:35 PM
HDs4me's Avatar
HDs4me
HDs4me is offline
Well there's now a Service Bulletin out about it
M1492: 2017 - 2019 Touring - Milwaukee Eight - Inner Primary Vent
dajogejr (05-18-2019)
Old 05-18-2019, 06:23 AM
Redrodyankneck
The following 7 users liked this post by Redrodyankneck:
103Eagle (05-18-2019), 2018sportglide (06-27-2019), bradsULtd (05-18-2019), Professor123 (03-31-2020), royston (05-27-2019), Steel Wheels (05-19-2019), tmac00333 (05-31-2019) and 2 others liked this post. (Show less...)
Old 05-18-2019, 08:39 AM
$tonecold's Avatar
$tonecold
The following 13 users liked this post by $tonecold:
04ctd (08-05-2019), 103Eagle (05-18-2019), 2018sportglide (06-27-2019), blacktop37 (05-18-2019), BrandonSmith (05-20-2019), EdsRoadGlide2017 (08-16-2019), Iron lHorse (12-06-2019), Jehu (07-19-2019), mjwebb (05-18-2019), Mountainkowboy (05-26-2019), Northernproducer (05-19-2019), Olgr1 (03-26-2020), Silentgreyfellow (05-18-2019) and 8 others liked this post. (Show less...)
Old 05-18-2019, 12:25 PM
TwiZted Biker
You should reword this then , the problem has or has not manifested again with the vent. From a purely mechanical standpoint that isn't a " fix ".
Old 05-18-2019, 07:33 PM
Redrodyankneck
I have 900 miles since the primary vent was installed by HD and happy to report the trans fluid is still at the full mark. Prior to the fix after 1,000 miles it was down 9 ounces.
Quick Reply: Let us know if your HD primary vent fix has worked or failed
