883 to 1200/1250
Old 07-15-2019, 05:59 PM
kopirokok's Avatar
kopirokok
kopirokok is offline
2nd Gear
Question 883 to 1200/1250
I see that higher displacement increases the HP but does this also increase top speed? Everything I have read talks about HP which to me is torque and how quick a bike can get from 0-60 etc. Thank you ahead of time.
Old 07-16-2019, 07:01 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Large torque and hp increase, across the entire rpm range.
Scott
__________________
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Maxton Mile World Record
4500 sq ft. facility
See us on Facebook.
Old 07-16-2019, 07:32 AM
Madnss's Avatar
Madnss
Madnss is online now
Received 1,059 Likes on 573 Posts
My 1250 with extra trimmings ran a 121.44 mph in 4th gear at 7600 rpm with stock gearing. Depends how much POWA you add. And of course, gearing, Redline ect
Old 07-16-2019, 07:33 AM
Madnss's Avatar
Madnss
Old 07-16-2019, 08:36 AM
Hillsidecycle.com
Sponsor
A good 1200 can generate about 85 ft/lbs or so, and cam/head/compression/intake and exhaust will dictate hp.
Scott
Old 07-16-2019, 09:53 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Thumbs up
Yes. If you do a 1250/1275 mod, for example as per Hammer, your engine will rev much higher than stock, which along with the extra HP will enable you to ride a darned sight faster. Torque is what accelerates you, HP give you high speeds.
Old 07-16-2019, 10:22 AM
Madnss's Avatar
Madnss
Read this, FYI: this was not written by Dan Dunn, the current and sole owner at NRHS.
http://www.nrhsperformance.com/tech_power.shtml
Old 07-16-2019, 10:34 AM
grbrown's Avatar
grbrown
grbrown is offline
"torque is what accelerates the bike, horsepower is what maintains the speed"
Old 07-16-2019, 09:19 PM
marcodarq's Avatar
marcodarq
marcodarq is offline
Primary , transmission and final drive gearing it what is going to manipulate your top speed capability. The thing that goes along with that is that your are going to have to have enough engine power, both torque and hp in order to have enough power for it all to work. Do you have a desired top speed in mind?
M
baka1969
04-29-2021 01:54 PM
homefront
04-24-2018 01:54 PM
Blue HD
03-19-2007 01:29 PM
sumncguy
12-08-2006 02:57 PM
chrism84
11-26-2006 10:04 PM
Quick Reply: 883 to 1200/1250
