Barnett extra clutch plate and finding neutral
I installed a Barnett extra plate clutch pack along with recommended heavy duty diaphragm spring last November (only a couple thousand miles). I have adjusted my clutch probably 30 times since and I still have an incredibly hard time finding neutral. About the only way I get it into neutral while the bike is running is shifting down from second gear, and it's not everytime. Shifting up from 1st is almost impossible to find neutral.
With the heavy duty spring, it can be a bear in heavy traffic, so putting it into neutral would be nice.
I'm running Bel-Ray V-Twin in the primary. This is my first time using it as I ran HD synthetic before.
I upgraded the clutch as I plan on a big bore kit, cams, and possibly head work. Figured I would upgrade the clutch first.
Anyone have any suggestions?
2005 Road King.
2005 Road King.
An extra plate kit, because it looses the inner judder spring in clutch pack can sometimes be a little harder to find neutral. I recently adjusted exact same clutch setup on a friend's 124. Even down to the bel-ray. No problem finding neutral.
You don't need that heavy duty spring unless you are planning on serious hp. Try an 03 or earlier stock touring spring. It will hold your big bore kit just fine. When adjusting clutch pack, with clutch cable slack, adjust per FSM except only back off adjusting rod only 1/4 turn, then lock down. Now adjust clutch cable per FSM.
ajtwin (04-28-2024)
The following 2 users liked this post by tdrglide:
Jay Guild (04-26-2024),
Lunatic_Fringe (04-26-2024)
as mentioned adjust the clutch pushrod, I like to adjust the cable with a little less free play as well and it seems to help, but make sure that you do actually have SOME free play. the other thing that helps is blipping the throttle and shfting at the same time,,,,seems like the pack loosens up some and can find N easier. this stuff works for me as I ran the xtra plate kits for a long time, before i started getting biggger badder clutch assemblies.
m
m
The following 2 users liked this post by marcodarq:
joenc (04-27-2024),
TwiZted Biker (04-26-2024)
This, no reason for it outside hipo street racer setup.
klammer76 (04-28-2024)
Received 19,665 Likes
