backfires at 1/4 throttle
Hello,
I own a Softail, 1987, pipes with baffles, CV carb (48/175), 1.5 turn mixture screw, and foam air filter.
The bike starts OK, idles OK and is running OK for complete rev range, with one exception => at about 1/5 or 1/4 WOT it backfires a lot, impossible to run. If I open the choke, at that time, it runs OK, no backfires at all. Thinking that pilot jet (48) is too small. I have spare pilot jets 50, 52 & 55 and also main 180.
Could you please share your toughts.
Thank you in advance.
Marcel
Marcel
Architect (05-01-2024)
marcelm (05-01-2024)
Is a new bike for me, don't know how it run before.
The carb is clean, just did it before the ride.
in the 1/4 range of WOT, the "active" jet is the pilot one, not the main jet.
Can I change the pilot jet, w/o taking apart the carb, by just removing the bowl?
Does the accelerator pump squirt? Last time you had it off did you change the carb/manifold seal? Have you ever had the manofold off?
Stock cam you would be fine with a 45/175. And bolt-in cam you're OK with 45/180 or 185. You can run a 48 but if you "need" a 48, it has an intake leak - period.
Spanners39 (05-01-2024)
Thanks for the answers.
But, considering your advices, maybe the 52 pilot jet is only covering the real root cause.
- the carb is clean,
- jets no clogged,
- I changed all rubbers into the carb,
- the accelerator pump squirt,
- I did not change the intake manifold seal,
- I did not had the intake manifold off,
- I don't know what cams the bike has.
