Passing light/running lights RK
05-23-2024, 04:26 PM
First which switch behind the triple trees controls the passing lights? Is the switch on the opposite side a dummy switch?
New to the touring bikes.... Dyna did not have them..
Thank you
05-24-2024, 03:18 AM
Brake lever side is p-lamps
Clutch side is aux
05-24-2024, 02:29 PM
Thank you... Now gotta check the fuse to make sure it's not blown, then check connections as they're not working.. Then again switch could be bad...
Anyway thank you for your time and help 88
jf7689
EVO
09-24-2015 05:19 AM
kkinderen
2014-2023 Touring Models
12-08-2014 01:14 PM
FOCI
Electrical/Lighting/Alarm
07-23-2009 07:30 PM
sat4314
02-22-2009 06:35 AM
LKHA
03-16-2008 03:33 PM
