dual outlet tire valve stems?
Old Mar 29, 2026 | 07:54 AM
undy's Avatar
undy
Default dual outlet tire valve stems?
I'm nearing front and rear tire replacements for my 2018 RK. FWIW, I use an Amazon sourced tire pressure monitoring kit that utilizes valve stem caps. It's been mentioned and shown here about valve stems that have dual outlets, one for adding air and the other for mounting the pressure/temperature monitoring cap. It allows you to add air to the tire and check pressure without having to remove the cap (PITA). I did an extensive search here and was unable to find the post/info about them. Any help? I'd like to purchase a set...
Old Mar 29, 2026 | 08:00 AM
MURPHCC1's Avatar
MURPHCC1
Never heard of them
Old Mar 29, 2026 | 08:27 AM
undy's Avatar
undy
Originally Posted by MURPHCC1
Never heard of them
Here they are, just need to find a viable source. https://www.hawksheadsystems.com/t-valves.html
Old Mar 29, 2026 | 08:37 AM
hattitude's Avatar
hattitude
They're called t-valves.
I've never used them, but FOBO offers them as an accessory for their tire pressure monitoring systems.
I know nothing about the size needed, etc.
This could help you start your research..
https://my-fobo.com/accessories
Old Mar 29, 2026 | 08:47 AM
penmaker's Avatar
penmaker
I've had the FOBO t-valves on my 2014 FLHTK for years. I don't use the FOBO caps anymore but I still have the valve stems. I've never had a problem out of them.
Old Mar 29, 2026 | 08:50 AM
MURPHCC1's Avatar
MURPHCC1
Interesting.......
Old Mar 29, 2026 | 09:15 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Active Streak: 30 Days
What did you set the temperature alert setting on the aftermarket TPMS?
I set the PSI alert at 3 under the Owners Manual recommended tire pressure.
I got a couple sets of these after reading that resent thread. Seems to be a big difference in tire temperature for my old 4X4 Toyota and a motorcycle recommendation. Like 160 and 190.
Do bike tire run that much hotter?
Old Mar 29, 2026 | 09:27 AM
elPrez's Avatar
elPrez
Had them on my old Ultra Classic, they worked flawlessly. for some reason I just used the standard metal one for my newer Limited
Old Mar 29, 2026 | 02:53 PM
Bluehighways's Avatar
Bluehighways
Wingstuff has them for $19 each. AliExpress is much less but then you'll get an import duty bill a few weeks or months down the road.
Here's the link to the Windstuff website for these: https://wingstuff.com/products/37222...or-fobo-2-tpms
I have them and the FoBo sensors on both of my bikes. With the FoBo App on my phone, it makes checking the tire pressures really easy.
FWIW they take CR2032 Coin Batteries that seem to last me about a year or two.
Old Mar 29, 2026 | 07:17 PM
Buelligan666's Avatar
Buelligan666
FOBO TPMS app now works with Android Auto.
