Killswitch/Starter Relocation Options
Old Today | 07:16 AM
FangsCycles's Avatar
FangsCycles
1st Gear
Default Killswitch/Starter Relocation Options
For those of you who got rid of the wires to your bars, what solution did you end up choosing for relocating your kill switch and starter button?
I wired some up to where my VOES previously mounted. Not sure if it will survive the hard miles, but we’ll see.
Old Today | 07:23 AM
Rounders's Avatar
Rounders
I got rid of my kill switch. But on road kings you got a big dash ignition switch on my ultra I try to avoid using it. Easier to replace ignition switch than kill switch bigger contacts too. But you are not breaking load
Starter button I put mechanical button on starter and I am putting in electric switch on frame under seat on one of hole
Putting starter on separate fuse than ignition
Old Today | 07:28 AM
Rounders's Avatar
Rounders
I got both started buttons from tc bros. Mechanical looks simple. The electric is small wires and makes me nervous for robustness but all the choices seemed that way. I think I will do second layer of heat shrink
I think I will install mechanical button on other bike
They also sell a lever they show on XLs. Didn't fit my TC. Do you really need electric button? I know someone without one
Old Today | 08:39 AM
FangsCycles
1st Gear
I’ve seen Prism Supply’s lever, and the non-lever version. The mechanical button on the solenoid is probably the cleanest and best value.
I tried it on this bike, but I didn’t love that it would crank without the key. It obviously wouldn’t start, but that plus the ergonomics of it (having to start it quick if you stall, and burning ur hand on your pipe) made me want a button and switch like this.
I broke like 3 trying to fit it in there, but they come in a 12 pack for $6.
But when the hog rattles the cheap chinese solder in 100 miles, and i’m on the side of the road with no power to my coil, i’ll let you know.
Old Today | 10:46 AM
OCSpringer's Avatar
OCSpringer
I relocated the key to under the battery tray using a bracket from prism supply...
and wired in posh mini switches on the bars for the starter button and kill switch in stock-ish location. I will only use posh swiches and buttons. Posh switches are expensive but will last forever (made in japan).
and I use a direct starter button on the starter as well for a backup.
I originally had reservations about being able to activate the starter with the bike off but with this switch (Nash) it doesn't look like a button and you have to really push on it for it to activate.
Old Today | 11:22 AM
Rounders's Avatar
Rounders
I like having back up button in case of failure. Without ignition on, bike will not run. It crossed my mind what if it stuck.
tinymike66
Engine Mechanical Topics
Jul 5, 2025 05:46 PM
va_samiam
Ironhead
Mar 20, 2022 11:38 AM
Jason Dunsworth
14
Jan 30, 2020 06:22 AM
Pinetop
Mar 10, 2013 11:35 AM
