Starter Jackshaft
Old Jul 1, 2025 | 07:37 PM
tinymike66's Avatar
tinymike66
Default Starter Jackshaft
I have a starter jackshaft from a 1989 electraglide
i noticed the coupler that slided onto the starter shaft and the end of jackshaft does not have an offeset, the snap clip inside is same distance from either end (in centre)
also when assembling where does the spring go?
mine doesnt seem to sit right
Old Jul 1, 2025 | 09:00 PM
GalvTexGuy's Avatar
GalvTexGuy
Old Jul 2, 2025 | 07:09 PM
tinymike66's Avatar
tinymike66
Originally Posted by GalvTexGuy
ok, so thats how i been installing it.
issue is it doesnt sit in the coupling it sticks out past the clutch sprocket.
i cant figure it out
Old Jul 2, 2025 | 07:47 PM
Tommy C's Avatar
Tommy C
Do you have #11 in the diagram installed backwards?
Old Jul 3, 2025 | 11:23 AM
tinymike66's Avatar
tinymike66
#11 supposed to be offset too....but I measured it and the snap ring is centre
same distance drom both sidss
Old Jul 5, 2025 | 12:15 PM
tinymike66's Avatar
tinymike66
Assembkes as per the HD repair manual
but it sticks out
Isn't the pinion gear supposed to be in the collet and clear of the clutch sprocket?
Old Jul 5, 2025 | 01:48 PM
jbarr1's Avatar
jbarr1
I believe the spring is possibly on the wrong side of coupling #8. Drawing is wrong.
https://empirecycleparts.com/categor...ers-89-93.html
Old Jul 5, 2025 | 05:46 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The pinion gear in the pic is way out of position.
Keep in mind, the 1989 Jackshaft assembly is not the same as `90 or later, it is a one year only assembly.
Ftwkm
Shovelhead
Jun 18, 2025 08:22 AM
Island Dude
Ironhead
20
Feb 8, 2024 06:07 PM
sunup420
EVO
Feb 7, 2010 11:58 AM
mikesta1
Welcome Area Only
Apr 23, 2007 11:20 AM
