Wires thru the bars question
Old Today | 09:57 AM
Scootertrash60's Avatar
Scootertrash60
Default Wires thru the bars question
2000 Ultra Classic, putting Wild1 Chubby 10" bars on.
Might be a dumb question. It's been years since I ran wires thru the bars on the wife's Road King, I left the factory loom tubing on.
When you guys run your wires thru the bars, do you leave the factory plastic wire loom tubing on the wires, or do you remove the wire loom material? With the extra wiring, I'm not sure if it will be more difficult on the Ultra.
Thanks!!
Old Today | 10:55 AM
btsom's Avatar
btsom
My personal belief is that the factory doesn't waste a nickel on something the engineers believe isn't needed. If the factory includes the tubing on a similar wiring bundle, they believe it is needed so they won't have to do a warranty repair. How soon do you want to repeat this job so you can repair chaffed insulation after being stuck in the boonies?
Old Today | 11:24 AM
skydude426's Avatar
skydude426
I made a video series a few years ago covering this topic. It might help you out. Here's a link to the first one.
Old Today | 11:37 AM
Rounders's Avatar
Rounders
You are going to tove the wires from the connector and run existing wires through bars?
I would leave it sleeved and use lube
Old Today | 11:51 AM
Old Sport's Avatar
Old Sport
Leave the sleeve…
Old Today | 01:18 PM
gonemad's Avatar
gonemad
I leave the black sleeve on.
Old Today | 02:33 PM
lp's Avatar
lp
Sometimes the factory sheath (wire protector) will not fit through the bars. If that is the case, take the wires out of the sheath and wrap them tight with electrical tape - or heat shrink the whole thing.
Ultra2336
Sep 6, 2021 04:38 PM
clap
Apr 5, 2017 08:07 PM
JHC210
2014-2024 Touring Models
11
Aug 29, 2016 12:48 AM
Rickey
Jul 21, 2014 01:55 AM
Sensei Jim
Jul 12, 2012 01:53 PM
