What weight transmission oil is right?
Old 10-21-2008, 05:07 PM
hawg08's Avatar
hawg08
hawg08 is offline
Default What weight transmission oil is right?
Is this good and if not what should I use?
RED LINE 80W MOTORCYCLE SHOCKPROOF GEAR OIL
Old 10-21-2008, 06:58 PM
jag1886's Avatar
jag1886
jag1886 is offline
I use 75-110 Amsoil Severe gear in mine, I would use a multi vis oil of some sort instead of the old straight weight stuff.
sniperduce's Avatar
sniperduce
sniperduce is offline
BelRay's Big-Twin 85-140 wt.
Old 10-21-2008, 07:07 PM
BadPiggy's Avatar
BadPiggy
BadPiggy is offline
The Redline you mention isn't the correct product.
It should read...
Redline: V-Twin Transmission Oil with Heavy Shockproof
This is a synthetic oil. Be certain that's what you want.
The color will be Pepto Bismol pink.
Although, the others mentioned are good oils, too.
Old 10-21-2008, 07:09 PM
sifularson's Avatar
sifularson
sifularson is offline
I use this Redline oil. I buy the powerpak with everything I need to change all 3 holes. I was using Amsoil and switched because my transmission was making noise when hot. It is much quieter with the Redline.
http://www.racerpartswholesale.com/p...otorcycle_Oils
Old 10-21-2008, 07:11 PM
Bluesssman's Avatar
Bluesssman
Bluesssman is offline
I use 85-140 Lucas gear lub and it keeps the trans quiet and running smoothly.
justme101 (04-26-2019)
Old 10-21-2008, 07:12 PM
sifularson's Avatar
sifularson
It should read...
You're correct Piggy. This is the listing for that oil.
http://www.racerpartswholesale.com/p...ansmission_Oil
Should be using the V-twin shockproof.
Old 10-21-2008, 07:14 PM
wbogley's Avatar
wbogley
wbogley is offline
My indy said to run 75-90 Amsoil. It really runs and shifts good.
Old 10-21-2008, 07:24 PM
themensh's Avatar
themensh
themensh is offline
How can you run Harley Syn in the engine (figure it's 20/50?)..then run the same stuff in tranny and primary?
Hard to imagine Harley runs 20/50 where others (here) say to run 85-140 weight.
Chuck
Old 10-21-2008, 07:29 PM
EasternSP's Avatar
EasternSP
EasternSP is offline
Received 21,930 Likes on 8,435 Posts
I changed my tranny oil in the RG over to the Red Line V twin shockproof this past weekend. I do notice the shifting noise is a bit softer now.
Quick Reply: What weight transmission oil is right?
