Hi thanks for the fast response. So the belt is in fact a smaller than the, what is it called, it's in? I checked other bikes and also my old Sportster has a perfect fit. Bike brand new so assume alignment is OK. Will monitor that though...
Just because it is new doesn't mean it is good. You should check the alignment for your own peace of mind.
That space between the belt and the sprocket is normal. On most bikes when you roll the bike forward the belt will slide towards one side and when you roll it backwards re belt will slide towards the other side.
If that belt was exactly the same width as the sprocket it would probably chew up the sides of the belt and damage the edges of the sprocket.
