Gas Tank Reserve Question
Old 06-10-2016, 12:46 PM
IRON1250's Avatar
IRON1250
IRON1250 is offline
Default Gas Tank Reserve Question
I have just picked up a 91 heritage and had filled the tank up. Today riding it started to sputter a bit so I reached down and put it on reserve.bat that it ran fine. Pulled in and filled her up and it took a little over 2 gallons to fill it. Is it normal to need reserve with that much gas left in it or is something a miss?
Old 06-10-2016, 01:22 PM
mdm's Avatar
mdm
mdm is offline
If you did actually start with a full tank, something other than fuel level probably caused the sputtering.
Old 06-10-2016, 01:33 PM
IRON1250's Avatar
IRON1250
IRON1250 is offline
I filled it myself. No sputtering after fill up set back to the on setting. Weird!
Old 06-10-2016, 01:44 PM
mdm's Avatar
mdm
mdm is offline
If it happens again try to identify the conditions present:
Steady speed
Accelerating
High/low RPM
Engine hot/cold
Straight
Turn
It could be numerous things:
Trash in the fuel tank/carb float bowl
Bad coil
Loose coil wire
Loose plug wire
Bad spark plug
Dirty fuel filter
Old 06-10-2016, 01:56 PM
IRON1250's Avatar
IRON1250
IRON1250 is offline
I think mdm may be correct that I'm not getting the tank fill. Will fill up again tomorrow as it looks like more will fit with the bike up right. Maybe I need some training on the dual filler caps!
Old 06-10-2016, 02:44 PM
Baddad1's Avatar
Baddad1
Baddad1 is offline
Just fill both tanks until visually full
Old 06-10-2016, 02:55 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,607 Likes on 4,660 Posts
Just put the bike on the jiffy stand, it does not need to be vertical to fuel it up.
I always fuel the low side tank first (left tank), put the cap on and then fuel the right side tank.
Is there an external fuel filter in the fuel line?
If so, get rid of it.
Old 06-10-2016, 06:09 PM
langwilliams's Avatar
langwilliams
langwilliams is offline
if it keeps doing it you may need to clean the screen on the fuel valve and or drop the carb bowl an check for debris.
you may also need to change the fuel line if it looks old.
Old 06-11-2016, 09:49 AM
IRON1250's Avatar
IRON1250
IRON1250 is offline
I just assumed that the tank was one open space I didn't realize it was separated? I filled from the high side and I guess it balanced out and the tank was not completely full?
Old 06-11-2016, 01:55 PM
splattttttt's Avatar
splattttttt
splattttttt is offline
tank lift installed? Just thought I'd add.
Quick Reply: Gas Tank Reserve Question
