B2166 code on FLSTC
Old 07-07-2016, 08:17 AM
cragmor's Avatar
cragmor
cragmor is offline
Stage II
Default B2166 code on FLSTC
This might be a stupid question, and I can test it when I get home, but curiosity has the best of me. If I switch my running lights off, will this code pop up? It did come up on my bike, but all lights are working, no LED's installed.
Old 07-07-2016, 08:51 AM
Bone Doc's Avatar
Bone Doc
Bone Doc is offline
Received 10,868 Likes on 4,113 Posts
Welcome to the forum
For others sake, B2166 is 'Running Lights Output Open'.
Since all of your lights are working, my recommendation would be to switch the running lights off. Then clear the code. Use the running lights as you normally would and see if the code returns.
If it doesn't you're good to go. It may have just been an isolated event. If it does return then I would look into it.
Old 07-07-2016, 08:57 AM
cragmor's Avatar
cragmor
cragmor is offline
Stage II
I will test it when I get home to see if I can duplicate it. It would make sense that turning them off would trigger that code since it is just a mechanical switch. As far as the bike knows, there is an open in the circuit somewhere.
jf7689
EVO
09-24-2015 05:19 AM
Sand_fiend
Electrical/Lighting/Alarm
12-23-2014 06:22 AM
lonwlf
Welcome Area Only
01-28-2013 10:00 PM
tlpenland
08-10-2010 10:57 AM
larrysroad
10-09-2006 12:13 PM
Quick Reply: B2166 code on FLSTC
