Bike doesn't want to run!
I drove 130 miles Saturday morning at speeds of about 75. That afternoon I drove back home at about 85. The 2013 Breakout performed flawlessly.
Yesterday I backed it out of the garage and cleaned it up. I didn't use any water. I just detailed it a bit with some spray-on cleaner wax and micro fiber cloths.
I decide to start it up to pull it back into the garage. It started right up then died, again and again. If I give it gas it runs but the minute I let go of the throttle it stops running. It also seems to be running just a little rough. When I put it away on Saturday it was running perfectly.
Any ideas???
Any ideas???
Fuel-air-electrical. One of these.
Is the tank low on gas ?
On my 12 deluxe there was a gas issue when i first bought it. I ran the gas low in the tank (not enough to make the gas light come on ) and the bike stop running. Dealer said they have to adjust the sending unit.
I put the trickle charger on it yesterday. I had an appointment to get the clutch adjusted so I called the dealer about the other problem. When I got home from work, I got the bike out, hit the starter and it started right up.
i rode it to the dealer. It ran flawlessly. They adjusted the clutch and checked the charging system. Everything was fine so in all likelihood I'll need to purchase a battery.
It's amazing how a weak battery can affect so many things. i'm relieced that it wasn't anything major.
