Drag when starting
Old 09-26-2016, 06:59 AM
jonmerrill's Avatar
jonmerrill
jonmerrill is offline
Default Drag when starting
Fully charged battery. New stator, rotor, and voltage regulator. Started great at first but now when I hit the starter, it acts like it shuts off, then fires up. Cleaned cables to frame and battery but still no help? Could it be a cable to starter?
Old 09-26-2016, 09:47 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,811 Likes on 1,064 Posts
It could be but it also could be that your bike, whatever model that is, is trying to start on the compression stroke.
Old 09-26-2016, 10:07 AM
saltlick's Avatar
saltlick
saltlick is offline
what was that fix again, mine does it to once its hot. You push the button and it starts to turn over then acts like it goes dead ,then all of a sudden Bang! it starts up. Only when its hot though.
Old 09-26-2016, 10:28 AM
aperdue's Avatar
aperdue
aperdue is offline
Tag for later
Old 09-26-2016, 10:45 AM
jonmerrill's Avatar
jonmerrill
Seems to do it hot or cold. Almost every time too. This morning did it first thing, but when I got gas, fired right up. Just worried about being stranded.
Old 09-26-2016, 10:53 AM
Pitbull_Dallas's Avatar
Pitbull_Dallas
Pitbull_Dallas is offline
How old is your battery? Even if it appears to be fully charged, I could have a problem. Also, at some point you might want to consider upgrading your battery cables. I did and it was like night and day in the way the bike cranks. The stock cables are borderline on size and current carrying apacity..
Old 09-26-2016, 10:58 AM
jonmerrill's Avatar
jonmerrill
Brand new battery. Less than 8 months old and kept on trickle charger. And did the cables when I found out it was something else.
Old 09-26-2016, 11:28 AM
AZRenegade's Avatar
AZRenegade
AZRenegade is offline
Your OEM battery cable isn't big enough to deliver the charge necessary to turn over your motor. Install a larger aftermarket cable and problem solved. You also might want to invest in a battery with a higher Cold Cranking Amps capacity.
Old 09-26-2016, 11:36 AM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
My bet is your solenoid washer needs to be cleaned up. If you had elec problems before that can be hard on a solenoid.
Old 09-26-2016, 12:32 PM
Pitbull_Dallas
What kind of cables did yiu go with? I went with Sumax and it was well worth the trouble..
Quick Reply: Drag when starting
