1999 Heritage Softail
I recently changed oil, used HD 20W50 as recommended, bike hadn't been ridden for long rides in about 4yrs. Although had been around the block a few times. Noticed while out on the road, oil temp was running somewhat higher than normal around 250-255 F'. Not sure what's causing this, any ideas will help. Thanks
Temp outside was around 90F. and I always run with premium gas. Heard I should try Lucas oil treatment. I'm thinking of draining oil and replacing with new but substituting with 1qt of Lucas. Read that this should reduce temp by 15-20 degrees. Please advise I'm open to any advice at this point.
Been sitting up are the key words. It's been awhile since I run across this but I always change fluids with a thinner oil for 50-100 miles then change it out with what's recommended. Fuel system needs attention too so I'll run a can of seafoam or something similar, amount varies on tank size.
Looking forward to pics, quite a few of us in here fond of the springer.
