Carb riders
Carb riders
I'm thinking of replacing my stk petcock with a pingel. What's everyone's thought on a vacuum operated petcock vrs a full manual petcock? They say with a full manual petcock you have to turn the fuel off every time you turn the bike off. I'm considering the manual just cause the new location on the tank would look a lot cleaner vrs having the extra valve on it.
I have a 1990 Sportster with a stock manual petcock. I do turn it off after rides, however I've left it on as I forgot and never had any issues. If your carb needle valve is good and the accelerator pump diaphragm is good you should be fine if left on. When my pump diaphragm went bad it did leak all over the place and basically emptied the tank on my garage floor.
I replaced the stock vac one with the pinglel...I used to turn the vac one off after riding too so I was already in the habit. If you forget once in a while it's ok as long as your float seats properly to shut off flow. I don't shut if off every time I park, just when I park the the night.
Received 14,261 Likes
