1992 Bobbed rear softail fender inquiry?
Old 06-30-2017, 10:17 PM
cycler's Avatar
cycler
cycler is offline
Default 1992 Bobbed rear softail fender inquiry?
Rebuilding my buddies 1992 softail after his got into an accident. New top end and S&S superstock heads, exhaust, and tank. But he decided he wants to change his rear fender. I ordered the Roland Sands rear tracker fender with struts from a buddy that has an online parts company. Bikers Choice had it listed on back order till June 22nd showing as the arrival date. Now they are showing an arrival date at their warehouse as July 17th and that isnt even set in stone.
Can anyone recommend a company that sells a bobbed rear strutless fender for a 1992 softail that is similar to the roland sands rear tracker fender that comes with outer struts to flow with the fender? Or without the the outer struts but a fender where I can mount rear blinkers.
Old 07-01-2017, 11:20 PM
langwilliams's Avatar
langwilliams
langwilliams is offline
they sell them on ebay.
Old 07-02-2017, 10:05 PM
stal94gt's Avatar
stal94gt
stal94gt is offline
I had the Roland sands fender and it was not my cup of tea to work with. First you are stuck using their seat or an expensive custom seat unless you button weld the fender and redrill it. Also you have to slam the rear end down pretty much down to the stops to get it to look tucked. It is also extreamly expensive. I would buy a cheap fender and chop it. Then you can fit it to use any seat and the stock frame horns.
Old 07-03-2017, 12:58 AM
cycler's Avatar
cycler
cycler is offline
I looked on ebay but those fenders were for 200mm tires. Ill email the vendors and see if they make them for 140 or 150 tires. Thanks for the feedback. And I already have the roland sands seat and yes its pricey and there are others that are so much better and cheaper
Pt0872
01-20-2013 09:16 AM
darkcustom48
03-09-2011 09:54 AM
schrammy21
07-24-2009 01:34 PM
NEW2BAG
12-07-2007 06:04 PM
95BadBoy
02-23-2006 04:27 PM
Quick Reply: 1992 Bobbed rear softail fender inquiry?
