New Fatboy runs crappy
I was referring to your assessment of the "Harley mystique". not HD motorcycles.
The best approach is to diagnose the problem first and then replace parts. Indiscriminate replacement of parts usually wastes money. Have patience. The problem will get fixed and then you can enjoy your Fatboy.
the Harley mystique got me but I’m now not sure
Received 14,178 Likes
It’s a single fire set up two Dyna 5 ohm Dyna S with that SE box wired in .
im gonna try and disconnect the SE box,if it does it again I’ll trace all wire continuity when it’s hot see what’s not happening right.
i heard the ignition modules can melt moving the air gap
btw it’s on the rear cylinder that this all occurs
R rear still misfiring when hot
ok I went through checked the Dyna S making sure the switches working on the off,checked make sure airgap specced out ,new 5.0 single fire Dyna coils, I found lil Allen screws that hold the ignition triggers a bit loose thought maybe “it”,adjusted the accelerator screw 2 out from stop it was 3 thought maybe to rich was it. Then test ride after it all after about 1/2 hr operating temp R rear craps out runs on 1 cylinder I’m pretty frustrated I just bought it and can’t even ride it.
anyway any additional ideas welcome on this Harley POS
I had a 98 fat boy loved it, never really had much of a problem. I replaced the stock cv carb with a mikuni, after it was started running rough. Iit took me a couple of attempts to get a jetted right but once I got to ride it ran great. I think what you're describing could be your carb jetted incorrectly or possibly some electrical problems I would suggest you take it to the mechanic you trust who's familiar with Harleys and see if you can exclude an electrical problem if it doesn't appear to be electrical it's most likely you need to rejet your carburetor. Electrical problems can be a b**** to diagnose so take it to somebody who knows what they're doing Evo Harleys are almost Bulletproof don't get discouraged all motorcycles have problems hang in there
Thanks it runs great until it gets really hot then R rear cylinder runs a weak spark when it cools down it’s back to normal so I know it’s electrical but haven’t been able to nail it .If wasn’t intermittently doing it It would be fixed by now.
Only explanatory fix is to get it to do it then try the diagnosis .
safe riding
safe riding
