Oil catch can location
Has anyone put an oil catch can or breather filter on their 2018 Softail Lowrider? Even if it's a different M8 Softail, where did you put the catch can? I bought a system from DK customs and am not sure where to put the can without it hanging under the bike. I am using the stock intake so there isn't room under that for the can like I've seen in some pics. Please include a pic or 2 if you can help! Thanks!
here is mine plumbed in so happy days
This is what i have bought for my FXLR 107 and i have plumbed her all up now. here are some pics
look closely the red KN Filter is cable tied nicely under the gearbox between the frame
After the first 1K miles I pulled the air filter cover and took a look at what was happening inside. I had VERY little oil residue in the housing and throttle body opening and I run my FXFBS pretty hard at times. With so little blow by happening I took the chance with really hiding the hose and filter. I used the $40 DK kit. I ran the hose out the backing plate (drilled a hole), up and over the rear cylinder, behind the left side cover and terminated the filter down by the swing arm hidden behind the exhaust. I got lucky with not having much blow by to deal with.
