Tubeless on spoke wheels ???
Actually, if the rim says tubeless, they are indeed tubeless spokes. I have a set that I modified a little to fit on my '06 Deluxe. They use a special rim liner that seals the tire to the rim.
Again, if it says "TUBELSS" on the RIM, it is tubeless. You cannot run a tubed tire on it. The tubeless liner fits under the tire bead, so you can't use those wheels without the liner. The tire just won't fit correctly
Received 47,791 Likes
Again, regardless of what the tire says, if the RIM says tubeless.....then it is tubeless
sailmotion (11-19-2018)
