2009 night train rear brake pad change?
Old 06-14-2019, 06:45 PM
Chris37's Avatar
Chris37
Chris37 is offline
2nd Gear
Default 2009 night train rear brake pad change?
Just bought a 2009 night train and the rear brake pads are worn too ****. First time changing brake pads on any motorcycle. Some people say the rear tire need too be removed and some say it doesn't. If any one can help me out a little that'll be great. Stock rear wheel also. Thanks
Old 06-15-2019, 12:29 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is online now
Received 1,811 Likes on 1,064 Posts
If you only had a Service Manual at your disposal, you'd know what to do.
Old 06-15-2019, 07:11 AM
Oz Nightrain's Avatar
Oz Nightrain
Oz Nightrain is offline
Mine's an 06 and you definitely don't need to remove the wheel to change brake pads. I did mine last weekend, it's a 10 minute job. Only reason to pull the wheel is if the rotor needs changing if it's been damaged or worn beyond specs. As mentioned get the manual, it will be the most useful tool in your garage! Good luck.
Chris37
06-14-2019 10:58 PM
2013superglideseattle
Milwaukee Eight (M8)
06-01-2019 02:26 PM
1004ron
09-02-2013 03:47 PM
Hollywood Ball
07-18-2011 06:48 AM
PDDGM
05-31-2008 10:56 AM
Quick Reply: 2009 night train rear brake pad change?
