1988 FLSTC spongy front break question
Hello,
So front break very spongy, when pulling in the front break lever can touch the grip.
So went old skool pulled in the lever attached to the grip over night next day it was nice and tight lots of pressure in the line. Morning after back to the same spongy.
Do I assume bleeding is the next step to get air out and or a complete change of break fluid to see it that works. Dont think it has been changed in many years
Thanks
Thanks
If the zip tie the lever over night is not working / holding. The next step is bled the line and IMO if your going to bleed it on an older bike that has not had a fluid flush / exchange just go ahead and completely change out the fluid, once you start bleeding its just more fluid.
Ive always used a vacuum pump (mity vac) or Harbor Freight has a kit that is cheap and will work easily on the bike or car. https://www.harborfreight.com/brake-...kit-63391.html
If that doesnt hold firm its master cyl time
Received 4,937 Likes
Rijan (08-29-2019)
At the minimum bleed the system, but if it has not been done in a long time, you might as well flush the fluid, make sure to use DOT 5.
Consider going through the complete system, rebuild caliper and master cylinder, replace the brake hose if it is original.
When rebuilding caliper, use OEM parts, aftermarket stuff is cheaper, but quality can be a crapshoot.
Rijan (08-29-2019)
Scarfmace
02-06-2013 09:32 AM
continentaldrifter
03-15-2008 09:34 AM
