Throttle Hesitation from Low RPM
One thing hattitude didn't mention is your accelerator pump. Check for a nice strong spurt when you twist the throttle-and make sure it's aimed properly. [That is shown on the site he linked to] The only other thing I can remember about the cv,or really any carb,is that the float height adjustment is crucial.
Oh,and,check for intake leaks [lightly spray some starter fluid on the intake,while the bike is idling,and notice if the idle speed increases]
Thanks folks, I think I will just drop the float bowl and do some cleaning . Only have about another month if lucky of riding so will focus on tires and then this carb cleaning . I think I can do it .
So I put a half bottle of sea foam in tank and that’s after I cleaned the C.A.R.B. with carb cleaner. It’s so mild now , that I think I’ll just let it be till winter . No issues accelerating , only when slowing down and I like to snap throttle with clutch in. I’ll see what the seafoam does I’ll try to run it everyday to get this gas out of it. I did try to spray some starter fluid around the manifolds and I did notice a very slight tick up in rpm’s but very mild and it leveled off very quickly. I used a a lot of starter fluid on all 3 sides lol. Anyway, anyone think it’s because I took the crankcase vent line out of the carb and put it on a filter somewhere else on bike? That extra air going in , I would think it would be even leaner . I ha e ridden about 200 miles with it like this without any issue . Just bouncing ideas. If not this winter I’ll take carb off , and take out jets and clean more throughly . Or put SS on it lol.
edit: one more question , sorry . I’m thinking of ditching the KN air filter and going with a uni , something with a little less air flow. Richen it up some, or maybe some long shots?
Update.. messing with it this afternoon, I noticed after rolling throttle making sure it’s squirting in the middle I noticed gas running out the back. Further investigation, I have gas coming out of the rubber boot where the accelerator pump rod is. Diaphragm issue? Please advise .
Maybe 2 problems . We will see. Plugs are bright white so would think if too much gas would cause a rich situation. I by no means am an expert mechanic , so I’m just going off research. I wouldn’t think gas would come out the vacuum hole if diaphragm was doing it’s job. However this may only fix one of my issues . Hoping that’s all it is and not float . But thanks for the info . I’ll be out of town for a week so when I get back , I’ll change and let you all know. Thanks and happy riding
when you pulled the crank breather off ...you have leaned the mixer out some ...then with the cooler air ...that will make it even leaner ...you may need to adjust the mixer screw up about a 1/4 turn ...and raise the pilot jet one number ...it's too lean !!
good luck !!
good luck !!
