Hello everyone, not a first time user but had to change accounts.
10-11-2019, 05:08 PM
My 2007 Heritage Softail front left running light does not come on, signal and emergency work fine. New bulbs, even switched with known working bulb. No corrosion. Any suggestions?
10-11-2019, 07:55 PM
Isn’t there a ground wire inside the housing of that running light? I bet after 12 years it may have rattled a little loose.
10-11-2019, 08:21 PM
Running light
Already checked the black terminal, it's tight and clean.
10-12-2019, 08:44 AM
Quote:
Originally Posted by
Catcher7591
Had to change accounts? Outstanding warrants?
10-12-2019, 11:45 AM
I ohm the black wire and compared too right side, 144 on bad side, 5 ohm on good side, where does this leave me?
10-12-2019, 12:25 PM
I think it means post number 2 is correct. Tighten up that ground wire or replace with good tight connections
10-13-2019, 08:00 AM
Cleaned, tightened the ground, still no good. Do not get contenunity from that ground to frame. Compared it too right side, got contenunity there, still quite puzzled here.
10-13-2019, 09:21 AM
Try a jumper wire from frame to ground in the light. Should tell you if the ground wire is compromised.
10-13-2019, 09:23 AM
Check the socket with a voltmeter, see if you are getting power to the contact for the running lamp element.
If the ground is bad, the signal lamp wouldn`t work either...
10-13-2019, 09:29 AM
Dan89FLSTC
Yes it would
