(06 Deluxe) rear master cylinder bracket removal
Old 10-22-2019, 10:22 AM
gun smoke's Avatar
gun smoke
gun smoke is offline
Default (06 Deluxe) rear master cylinder bracket removal
I'm trying to remove the rear master cylinder bracket on 06 deluxe to put a kuryakyn brake pedal on,or the two on the master cylinder.Can someone tell me what size torx I need to get them off,these screws are on there super tight and I just want to make sure I got the right size torq wrench.
thanks
Old 10-22-2019, 10:55 AM
bad tappets's Avatar
bad tappets
bad tappets is offline
You need an Allan wrench, not tore.
Old 10-22-2019, 11:47 AM
Mike NY's Avatar
Mike NY
Mike NY is offline
Seems the best choice would be to by a socket set of Allen sockets. This way you have a variety of sizes for now and the future...
Mike
NY
Old 10-22-2019, 12:23 PM
gun smoke's Avatar
gun smoke
this photo is not from my harley,don't no what year it is but it is setup different than my 2006 flstn deluxe,they make it look easy take the two torq bolts out then pull the cotter pin out,after I pulled the cotter pin out the clevis wouldn't budge and it's just to tight to work in that small space so i'm trying to loosen the rear master cylinder bracket.can't even find it in there 2006 service manual that I paid over hundred dollars for used.
Old 10-22-2019, 12:45 PM
Mike NY's Avatar
Mike NY
Mike NY is offline
I would have to take a look at my bike. I never changed the Rear Master Cylinder....
Mike
NY
Old 10-22-2019, 12:58 PM
Mike NY's Avatar
Mike NY
Mike NY is offline
The Parts Manual is a better option for showing how things are connected since they usually have an exploded view.....I can take a look at that as well...
Mike
NY
Old 10-22-2019, 01:16 PM
Mike NY's Avatar
Mike NY
Mike NY is offline
Here is a good place to find manuals.....just put in your year bike and model in the Search Box up in the Right Corner..
https://serviceinfo.harley-davidson.com/
Mike
NY
Old 10-22-2019, 01:22 PM
Mike NY's Avatar
Mike NY
Mike NY is offline
Old 10-22-2019, 02:35 PM
gun smoke's Avatar
gun smoke
Mike
NY
Harleys telling me I need torq the newer Harleys are setup different than my 2006 here is the picture of mine,the other pic is a newer Harley.
Can someone tell me if this is a torq screw or an allen,my bud says allen.
Old 10-22-2019, 03:43 PM
gun smoke's Avatar
gun smoke
Mike
NY
I am not changing the master cylinder i'm trying to install a new brake pedal and need to loosen the master cylinder to slide the pedal on and having a real hard time,all the videos on youtube are showing newer bikes and I guess there different,you can see the patteren.
thank's
Quick Reply: (06 Deluxe) rear master cylinder bracket removal
