Softail Rocker owners with stock seat... need pics
Quick question for rocker owners with a stock seat. Can I get a pic of the back side where the rear fender goes next to the frame? Trying to figure out if there is some form of cover the rocker has back there. With my spring seat on the breakout, it leaves some electronics exposed. So attempting to either make something or acquire something to cover this part up.
I have this photo, not very clear, but you can check , there are a plastic piece in the back side of the seat.
Also, you can check "HD parts finder" and view the diagram of the pieces.
https://partsfinder.onlinemicrofiche....asp?make=hdmc
I had to read your build post to understand what you were talking about with the spring seat. i looked at what you have done so far and it looks good. the one thing i noticed is you have a lot crammed under your seat. When i did mine i moved the ECU behind the rock guard which freed up a ton of space. I was able to get my seat pan real low which once I swapped out to a low profile battery i could have made the seat pan flush to the frame covering all my electronics.
Here’s what I’m looking at. Normally this is covered up with a breakout fender. And it appears part of the rocker seat also covers it up. I might just fabricate a lip to bolt underneath the battery cover to obstruct the view.
