2004 Softail Deuce is lifeless
2004 HD Deuce is seemingly dead. When I turn the ignition, NOTHING comes to life. No lights at all, no fuel pump, no click, no start. This has happened 2xs before and the problem seemed to fix itself. No signs whatsoever that this was a problem that was going to happen sooner or later. Everything worked fine 1 minute then completely dead the next minute. Battery has been on tender and is above 80% charged. I changed out the relays and all fuses are in working condition. Any ideas?
I agree to check all the battery connections... positive connections and especially grounds....
My 2003 Heritage has had slow, labored starting symptoms a few of times over the years....
First time, I replaced the 6 yr old OEM battery and it didn't fix the problem.... I then found the negative battery cable, where it screws into the frame, by the front of the seat, was loose... Not sure if you have the same connection on a Deuce...
It's happened 2 more times since, and each time it was that particular connection getting loose... I put a new star, lock washer on it every time I need to tighten it... and yet it still works its way loose over time...
Go figure..
Go figure..
Try cleaning your ignition switch connections.
https://www.hdforums.com/forum/softa...le-riding.html
Iron lHorse (10-09-2020)
Jackie Paper
01-28-2014 07:47 AM
