Softail died while driving, need help getting back on the road
Hello guys,
I really need some help. My 05 Softail died while driving and is now stuck on a parking lot.
After the engine turned off while driving I checked the fuses, all are good.
What is weird is that when turning to Ignition it is dead. On Accessoires the tail lights are on (sometimes flicker).
When i am on Ignition and remove the headlamp fuse my odometer comes back but the system relay is clicking. Still not starting without the headlamp fuse tho.
Now I am a bit clueless what could be the issue and where to look at.
Thanks for any help and sorry if my english is not perfect. :-)
Received 1,637 Likes
Roddie (07-16-2021)
My guess is the ignition switch on the console is corroded. If you can get the console off with a 1/2" wrench and maybe wiggle the wires to get it to work so you can get home to clean it.
Here is a link to a how-to on cleaning it.
https://www.hdforums.com/forum/softa...le-riding.html
Roddie (07-16-2021)
Okay i went there in the dark now. Checked battery cables, retightened them. Also checked the ignition, no corision. Anyway made it clean + some WD 40.
Nothing helped. I think this will take some more research. Probably have to get it towed home first tomorrow.
Could some wire be blank and cause this issue? Maybe gonna get a new battery just out of curiosity first.
Really a pitty, i hate eletrical issues. They are pain in the *** sometimes.
I will keep you updated!
slothtail (07-16-2021)
Don't just change your battery. I did that,and it turned out to be a bad ground. I'm pretty sure someone with a softail will be along to help you find your problem.
Roddie (07-16-2021)
