Softail won't start
Old Dec 5, 2021 | 07:39 PM
Allen Forrester's Avatar
Allen Forrester
Stage II
Default Softail won't start
2010 Softail only starts when I spray ether into the air cleaner. Why won't it run with just gasoline?
Old Dec 5, 2021 | 07:49 PM
MURPHCC1's Avatar
MURPHCC1
cause it aint getting any?
Old Dec 5, 2021 | 08:35 PM
Allen Forrester
Stage II
What could be causing it to not be getting any gas?
Old Dec 6, 2021 | 12:12 PM
SirHarley's Avatar
SirHarley
First of all stop spraying ether into your carb to get it to run. Unless you want premature ring and piston wall wear. Use a good carb cleaner which is really an alternative fuel in reality. It won't harm your engine when you use it. Secondly, you need to find out why gas isn't making it to the combustion chamber. Do you have fuel injection? It could be a myriad of things, so start at the fuel tank and go forward from there.
Old Dec 6, 2021 | 01:15 PM
diablos's Avatar
diablos
symptom of the infamous fuel line pinhole? remove the fuel cap and listen for fuel spray while the pump is running. you can also remove the dash and fuel pump access for a better look.
Old Dec 7, 2021 | 11:43 PM
kculp's Avatar
kculp
If you have fuel injection, should hear the gas line pressurize when you turn the key. All 07 electro glides wereEFI (Looking at your bike pic). If you have a fuel pump problem, start there. I assume you have battery power and your starter is firing up.
musicnbikes
Apr 30, 2023 02:38 AM
89Speedy
Screamin Eagle CVO Models
Jul 28, 2012 04:30 PM
mori55
Air Suspensions
Jun 17, 2011 10:32 PM
agapsdiver
Custom Models
Feb 19, 2007 01:41 AM
