2004 heritage classic
Old Apr 5, 2022 | 02:24 PM
MarkW8859's Avatar
MarkW8859
Stage I
Default 2004 heritage classic
I have a 2004 , I replaced the fuel gauge with a willie G skull led gas gauge. since day one the low fuel gas lite is lit with any amount of gas in it. Any fixes? Thanks in advance
Old Apr 5, 2022 | 06:15 PM
hattitude's Avatar
hattitude
I have no knowledge about that fuel gauge...
However, if it is listed as fitting an '04 Heritage, I would suspect that it installs like the OEM. You feed the wires (#26) through the "tunnel" from the fuel gauge recess to the bottom of the tank. You then put on the connector (#25) and plug that into the harness by the back bone of the frame.
Maybe when the new connector (#25) was pinned, and then plugged it into the harness connection, a pin got bent that's not making contact... I'd check that connector..
FWIW... I could not find a Willie G Skull LED gas gauge that fits an '04 Heritage...
I only found one that fits '08+ Softails...
If your gas gauge is #75098-08A, it may not be working correctly because it's not designed to work with your bike...
csonni
General Topics/Tech Tips
Oct 29, 2021 06:53 PM
lstcause616
Softail Parts
May 4, 2021 09:22 AM
tukeiam
Apr 8, 2018 04:30 PM
phellowship
Feb 17, 2014 12:05 PM
davered51
May 21, 2007 09:06 PM
