Softail EVO/TC race cups removal
03-25-2024, 08:51 PM
The picture shows the frame with the steering head outer race removed.
There is nothing else to be removed from that steering head.
Here`s my `89 Softail frame with the outer race removed:
03-25-2024, 09:06 PM
The pic in post#1 still has the Race installed.
If needed use the maginifier on your viewing device
But ... Maybe you meant your pic, but said "The pic" (which threw off) instead of "This pic" or "My pic"
03-25-2024, 09:10 PM
Quote:
Originally Posted by
Harley_ish
Both pictures show the race removed.
Here is the race:
03-25-2024, 09:13 PM
Ok, then you were wrong after all, the pic in post #1 still has the Race.
Thanks for clarifying
03-25-2024, 09:17 PM
Harley_ish
The OP said the outer races were removed in his pic.
Even when the races are removed, it still looks like there is a detail pressed into the neck.
03-25-2024, 09:39 PM
back again
Thanks for proper name races hattitude. I tried a bearing race remover and hated it after trying it twice. I’m old and use old school tactics. Was taught how to take out axle races with an arc welder. Strike a bead on two sides of the race and leave stick on the race and you can pull the race out with the stick .It can be done with a mig machine and punch after you weld. You just have to be more careful on the bike. Not for beginners by any means. My old man taught me this in the 60’s. I sure do miss him.
You were lucky to have him teach you those tricks...
That is one skill I never acquired in all my years of working on cars, bikes, or boats.... I really wish I had someone teach me how to weld...
03-25-2024, 10:39 PM
Neck Bearing Race Puller, Heavy Duty High Strength Steering Neck Bearing Race Remover for 1‑1/8in to 2‑5/8in ID Races
https://a.co/d/bCwGr4r
Amazon, less than 20 bucks.
03-31-2024, 12:44 PM
Run a ring of weld around the race and it will fall out when it cools and contracts.
suicidexclub
02-18-2020 08:58 PM
LE PARRAIN
12-01-2014 03:29 PM
rowan
05-26-2013 08:40 PM
tomfiii
EVO
11-10-2012 11:08 AM
polish hammer
EVO
11
03-30-2012 04:03 AM
