REAR BELT KEEPS LOOSING TENSION?
Old 09-07-2007, 07:35 PM
DCS's Avatar
DCS
DCS is offline
Default REAR BELT KEEPS LOOSING TENSION?
07 FLSTC, I have adjusted my rear belt deflection several times acording to the servive manual and within 9/16" - 5/8" of deflection.Afterabout 4hundred miles later the belt will have lost some of it's tension, not strung as tight as it was. The axle adjusting bolts have not moved, the threads have been counted and the top flat of the bolt head marked. After adjusting belt tension I check to make sure rear wheel is alligned. Crazy thing is, when I re-adjust the belt to be tighter or in spec, the rear axle adjusting
bolts end right back where they were B4? Good at first then loses some tension.
Is this normal? Wouldjust riding & going over bumps and such cause this? I have looked at older models of Heritage Softails and they all have a much wider rear belt than the 07's, could the smaller belt be more prone to loosing tension?
Thanks For Any Input,
Dan
Old 09-07-2007, 07:47 PM
HD7585's Avatar
HD7585
HD7585 is offline
Default RE: REAR BELT KEEPS LOOSING TENSION?
Check the final tension with someone sitting on the bike. The belt is tighter with a riders weight. Maybe the belt is to tight with a load on the bike and this causes it to be streached when you ride over bumps etc
Old 09-07-2007, 07:49 PM
clutchglass's Avatar
clutchglass
clutchglass is offline
Gotta admit I'm stumped here. Are you using a torque wrench on the rear axle bolt? Just reachin really, but I'm interested in seeing how this one turns out.
-clutch-
Old 09-08-2007, 06:29 AM
DCS's Avatar
DCS
DCS is offline
Yes I am using a torque wrench on the rear axle bolt, 65 ft.lbs.
Later,
Dan
Old 01-26-2015, 02:47 PM
emora's Avatar
emora
emora is offline
6th Gear
I'd like to resurrect this thread because the same thing is happening to me and I cant find an explanation. Broke a drive belt 12 months ago. 10 months ago the rear end was aligned and belt tension set. Today, the marks on the rear axle cam bolt have not moved but belt was loose enough to chirp on decel.
Old 01-26-2015, 04:52 PM
professorzoogy's Avatar
professorzoogy
professorzoogy is offline
check your swing arm bearings .
Old 01-26-2015, 04:54 PM
turbotom1052's Avatar
turbotom1052
turbotom1052 is offline
use some white out to place a witness mark on each side of the axle in line with the swing arm. Then you can see if and how much its moving.
1890jd
EVO
32
07-27-2020 03:49 PM
Shari Davis Coleman
07-19-2019 12:32 PM
Alain
10-07-2012 08:43 PM
kjkustoms
12-06-2008 07:26 PM
chevelless502
06-02-2005 07:42 PM
Quick Reply: REAR BELT KEEPS LOOSING TENSION?
