Belt tension?
Old Dec 6, 2008 | 04:41 PM
kjkustoms's Avatar
kjkustoms
Question Belt tension?
Just wondering if someone has any tricks to get correct belt tension? Just installed a new 180 and squaring up the rear end , can't seem to get it right.
Old Dec 6, 2008 | 04:47 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
There is a good post on rear wheel alignment in the DIY tech threads. You cam make a measuring tool out of a copper rod.
Old Dec 6, 2008 | 07:14 PM
gmc1999's Avatar
gmc1999
Rear Belt Drive Adjustment
Performance and Technical information on the rear belt drive for Harley-Davidson motorcycles.
Belt Drive Adjustment for Big Twins
Set belt tension a the tightest rotational point on the sprockets.
The adjustments should be done when the bike is cold.
The adjustments should be made with the weight of a rider on the bike.
1. At the lower strand, position "A", mid-way between transmission sprocket and rear wheel sprocket, apply 10 Ibs. of upward force on lower span of rear belt. Harley-Davidson has a BELT TENSION GAUGE (Part No. HD-35381) to help.
2. Measure belt deflection "B" several times, each time with belt moved (by rotating rear wheel) to a different position on sprockets. With sprockets rotated to tightest belt posi-tion, belt deflection "B" (measured at position "A") should be 5/16-3/8 in.
ADJUSTMENT
1. Loosen rear axle nuts.
2. Measure each side from the flat to the end of the swingarm, to be sure rear axle is correctly located.
3. Turn axle adjuster nuts (metric) on each side of swing-arm to adjust belt deflection.
a. Turn clockwise to decrease deflection (increase tension).
b. Turn counterclockwise to increase belt deflection (decrease tension).
Turn each adjuster nut exactly the same number of turns to maintain rear wheel alignment.
5. Tighten axle nut to 60-65 ft-lbs.
http://www.nightrider.com/biketech/hdbeltdrive.htm
Old Dec 6, 2008 | 07:26 PM
50cal's Avatar
50cal
I've heard of some "old school" wrenchers twist the belt by hand. It should twist to about 45 degrees, a little more... too loose, a little less... too tight. Dunno. I still use the handy-dandy HD tension guage for the most part, but, did use the old school method at the same time and it was about spot on.
Shari Davis Coleman
Jul 19, 2019 12:32 PM
Iarecobra
May 7, 2017 01:09 AM
Fine09
Feb 10, 2017 07:44 PM
DCS
Jan 26, 2015 04:54 PM
HDF Tech
Aug 7, 2005 04:25 PM
