Brake pedal
Old Dec 14, 2007 | 05:56 PM
scratchit's Avatar
scratchit
Default Brake pedal
A buddy of mine has a 06 Softail Standard and likes the bigger brake pedal on my Deluxe. I just saw a brake pedal off a 07 Softail Heritage on e-bay that I would like to get him for Christmas does anyone know if this will interchange?
Old Dec 14, 2007 | 10:15 PM
safields's Avatar
safields
Default RE: Brake pedal
I put Kuryakyn p/n 8044 on my FXST. It's an easy bolt-on and is wider than the stock brake pedal.
Old Dec 14, 2007 | 11:19 PM
Kevinc's Avatar
Kevinc
It should fit. Same engine, same frame, but I couldn't say for sure.
Old Dec 15, 2007 | 01:38 AM
Trailfndr's Avatar
Trailfndr
The larger size pedal is simply a cover over the existing brake lever arm. Most are interchangable so you can have several designs available with either the small or large size.
They typically run from around 30.00 to upwards of 60.00 depending on the style. Too many options for design to count.
Most Brake pedal pads will fit both the touring and 86 and up Softails.
If you get the part number from the e-bay site, you can check for yourself as to fitment at teh following site. Search by bike year and model, Look for decorative collections to find brake lever pads
http://www.harley-davidson.com/gma/g...7811!7005!8005
Hdbkstl
2018+ Softail Models
Apr 10, 2019 03:45 PM
HDV-GLIDE
Jun 3, 2014 02:31 PM
bigh8840
2014-2024 Touring Models
18
Apr 7, 2014 12:11 PM
bigh8840
Apr 5, 2014 10:52 AM
oldgeezermike
Oct 20, 2013 05:02 PM
