POPPING
Old Mar 20, 2008 | 06:49 PM
Queensland's Avatar
Queensland
1st Gear
Default POPPING
I HAVE A2008 SOFTAIL STD V&H FUELPAK BIGSUCKER A/C .BIKE POPS ON DECEL AND ALSO WHEN TRY TO KEEP TO TOWN LIMITS 60KPH/35MPH IN2ND OR 3RD GEAR THERE ARE NO AIR LEAKS ANY WHERE I AM ALSO RUNNING V&H PROPIPE .MY QUESTION IS HAS ANY BODY BEEN ABLE TO TUNE A EFI BIKE TO THE POINT WHERE IT DOES NOT POP ANYWHERE IN ITS THROTTLE RANGE .IF SO WHAT SET UPS DID YOU USE.WOULD VERY MUCH APPRECIATE ANY INFO AS I AM JUST ABOUT READY FOR ONE OF THOSE WHITE JACKETS .
Old Mar 20, 2008 | 07:29 PM
tk353's Avatar
tk353
Default RE: POPPING
get a dyno tune
Old Mar 20, 2008 | 07:40 PM
Deluxechuck's Avatar
Deluxechuck
Default RE: POPPING
Go to Vanceandhines.com. There is a link to their tech support. Email them and tell them what kind of bike/pipes/ac you have, and tell them what the problem is and they may be able to help you.
Old Mar 20, 2008 | 08:31 PM
ecoli's Avatar
ecoli
Default RE: POPPING
The only problem you have is that it hasn't been dynoed. Spend the money, it'll maximize all of your additions for hp, tq, and mpg.
Old Mar 20, 2008 | 08:57 PM
6165hd's Avatar
6165hd
Default RE: POPPING
I had the pop, snap, and crackle,,,,,,,,,,,dyno tune $200.00, bike runs like a dream, at any speed, up, down, anyway you throttle, no more BS.!
Old Mar 20, 2008 | 09:35 PM
Strgzr's Avatar
Strgzr
Default RE: POPPING
Called Vance and Hines on this issue. Hey had me change mode 23from16 to15. Cured most of my decel pop.
Mike
Old Mar 20, 2008 | 10:40 PM
bcox's Avatar
bcox
Default RE: POPPING
You have a 2008 Softail Standard ???? I thought they stopped making them in 2007 . . . sorry, just kinda odd.
Old Mar 20, 2008 | 10:50 PM
gwalsh's Avatar
gwalsh
Default RE: POPPING
They are still made for the export market.
And if I am corect, with a username like Queensland he is prob from Austrailia.
Old Mar 21, 2008 | 09:11 PM
Queensland's Avatar
Queensland
1st Gear
Default RE: POPPING
hello 6165hd
what set up do you have on your bike? it would be good to get my bike to run like yours. I have been to a dyno and he could not do it. have been in contact with V&H via emails and phone. phone is the only way to get hold of them as rarely answer emails.
Old Mar 22, 2008 | 01:24 PM
Hrd Rider's Avatar
Hrd Rider
Default RE: POPPING
I have the same snap,crackle and pop that 6165hd had. Had my bike Dynoed at a Stealership here in MD. After two hours, five test runs by me and a $200 tab, I still have the same snap,crackle and pop, A/FR is 14.2, HP 73,TQ 82.9and the bike runs well. I was told by the Dyno Guru who did my bike that he could not get rid of the decel popbecause of my exhaust, AC and SERT combination. I have had same problems on previous Harleys with PC's and DFO's but after raising HellI could always get the problem solved. I do know for a fact that this problem can be cured, I just have to find a competent Dyno Tech. Each Stealership claims to have a Dyno Tech that canwalk on water. I live 25 miles south of York,PA in N Central MD. IHAVE BIKE WILL TRAVEL, does anyone definitely know of a competent Dyno Tech? 6165hd, what year bike do you have and where in NE PA did you get your bike Dynoed?
Hrd Rider
2008 Heritage Classic
K&N AC
Rinehart Slip On Mufflers
HD SERT
