Gas smell
Old 05-06-2008, 05:47 PM
Pat C's Avatar
Pat C
Pat C is offline
Default Gas smell
I have an 07 Fatboy with VH BR & fuelpak. Lately when I come home from ride and bring bike in the garage Ismell gas, and this time the tank is no where near full. Is this normal or should I be concerned?
[IMG]local://upfiles/45014/D3E475F1D8554CD48EF2CD241B7527B2.jpg[/IMG]
Old 05-06-2008, 07:54 PM
WARG's Avatar
WARG
WARG is offline
Default RE: Gas smell
I get this sometimes too. It could be fuel gases venting out, or unburned fuel in the header pipes. Probably nothing to worry about, unless you find an actual fuel leak.
Old 05-06-2008, 09:27 PM
nobody1973's Avatar
nobody1973
nobody1973 is offline
Mine does the same thing. I was told this is normal.
Old 05-07-2008, 02:06 AM
bensonjv's Avatar
bensonjv
bensonjv is offline
Could be PC has you too rich in some or all of your map.
Old 05-07-2008, 06:38 AM
screamn_eagle's Avatar
screamn_eagle
screamn_eagle is offline
NO WORRIES, ITS NORMAL. mine does it sometimes. warg hit it on the head, gasses venting. when you shut the bike down, it actually heats up, initially, because you have stopped moving. the fuel also heats up and expands, so it vents out through the pipes and a/c...thats what you are smelling.
Old 05-07-2008, 06:39 AM
screamn_eagle
UMM I DID WANT TO MENTION...make sure you do look your bike over for any fuel leaks. make sure you have no fuel puddeling in the garage floor....then NO WORRIES[8D]
ZachGrove1
08-28-2018 07:07 PM
Jim Fortini
Exhaust System Topics
05-30-2011 07:28 PM
Shrug
05-03-2008 08:49 PM
Trash Rat
08-31-2007 06:08 PM
jim63b
17
06-28-2005 01:55 PM
Quick Reply: Gas smell
