Maxi Fuse - Installing a spoiler
Old 06-13-2008, 12:07 AM
HelluvaDoormat's Avatar
HelluvaDoormat
HelluvaDoormat is offline
Default Maxi Fuse - Installing a spoiler
Is the "maxi fuse" in the fuse box?&nbsp\\; If so, can you tell me which one it is and if there is something special I need to do&nbsp\\;prior to&nbsp\\;removing it?&nbsp\\; I'm installing a spoiler on my bike and the directions say to remove this fuse.&nbsp\\; I'm thinking it is because I have to disconnect my voltage regulator.&nbsp\\; Can I just disconnect the battery??
Old 06-13-2008, 06:18 AM
BlackDragon's Avatar
BlackDragon
BlackDragon is offline
Default RE: Maxi Fuse - Installing a spoiler
If You have an alarm and just disconnect the battery it will go off till U reconnect.
&nbsp\\;
The Maxi fuse is uner the seat in front of the battery. It is large and has a big black cover over the fuse.
Pull the cover off and U will see the large Orange fuse.
Turn your ignition on and pull the Fuse straight away.
U can disconnect the battery.
When u want to reconnect just plug it back in after connecting the battery.
&nbsp\\;
Hope this helps.
Old 06-13-2008, 06:46 AM
HelluvaDoormat
Do I leave the ignition switch on once I pull the fuse?&nbsp\\; Then whan I'm done with my install just reinsert the maxi fuse with the&nbsp\\; ignition still on?&nbsp\\; I do not have an alarm but I have LoJack.&nbsp\\; If I pull the battery is that as good as pulling the fuse or do I still&nbsp\\;have to pull&nbsp\\;it?&nbsp\\;&nbsp\\; Sorry for all the questions and thanks for&nbsp\\;your response.&nbsp\\;
Old 06-13-2008, 03:49 PM
Archer1968's Avatar
Archer1968
Archer1968 is offline
I put the spoiler on my 07 FXST, i just removed the negative side of the battery.&nbsp\\; Worked great for me your still killing the power either way.
Hurricane19
10-17-2013 09:11 AM
SCHOONER
12-17-2011 08:39 PM
JimmySG
11-29-2011 10:43 AM
SCHOONER
EVO
11-24-2010 09:33 AM
ack5225
Welcome Area Only
16
12-01-2007 08:47 PM
Quick Reply: Maxi Fuse - Installing a spoiler
