front axle cover problem
Old 06-25-2008, 08:08 PM
crazytrain1's Avatar
crazytrain1
crazytrain1 is offline
Default front axle cover problem
&nbsp\\;&nbsp\\; I just bought new axle covers for the front of my 07 nightrain. The set screw is too short so i went to the local hardware store but seem to experience a little problem. The bigger screw does work well but the cover is so big that it moves up and down as well as side to side. In order for the cover to sit flush i need to fill the extra space on the inside of the cover so it does not move but still able to get the cover off if need be. I was thinking of taking up the space with plumbers putty????not too &nbsp\\;hard but able to settle enough for me to tighten down the screw flush with the forks.&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\; Any info on what would work would be greatly appreciated..
Old 06-25-2008, 08:27 PM
trafficjams's Avatar
trafficjams
trafficjams is offline
Default RE: front axle cover problem
ORIGINAL: crazytrain1
&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\;&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;\\\\\\\\\ \\\\\\\\\\\\\\\\\\\\\; I just bought new axle covers for the front of my 07 nightrain. The set screw is too short so i went to the local hardware store but seem to experience a little problem. The bigger screw does work well but the cover is so big that it moves up and down as well as side to side. In order for the cover to sit flush i need to fill the extra space on the inside of the cover so it does not move but still able to get the cover off if need be. I was thinking of taking up the space with plumbers putty????not too &nbsp\\;\\\\\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\;hard but able to settle enough for me to tighten down the screw flush with the forks.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\\ \\\\\\\\\\\\\\\\;&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;\\\ \\\\\\\\\\\\\\\\\\\\\\\\\\\;&nbsp\\;\\\\\\;\\\\\\\ \\\\\\\;\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\;&nbsp\\;\\\ \\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\; Any info on what would work would be greatly appreciated..
&nbsp\\;\\\\\\;
regarding the moco axle covers...
&nbsp\\;\\\\\\;
they should have come with two different length set screws. the short one is for the cover you put on the axle (round)&nbsp\\;side. the longer one for the cover you put on the nut side. maybe you mixed them up and have already used the longer one on the wrong side? if its a moco cover kit and you didnt get the two different length set screws, go back to see your dealer?
harley0711
Softail Parts
10-04-2015 07:45 PM
1stHD_95FXDWG
03-11-2014 05:37 PM
mls02
01-22-2014 02:07 PM
rdown1976
08-11-2010 07:36 PM
20NightTrain03
07-24-2006 03:41 PM
Quick Reply: front axle cover problem
