Tank emblem
Old 07-01-2008, 11:31 AM
jefnightrain's Avatar
jefnightrain
jefnightrain is offline
Default Tank emblem
Got an 06 night train with the metal HD emblam attached with I assume a heavy duty 2 sided tape. How to remove if I want to do some stuff to the tank without hurting the original paint job. I certainley can't exactley take a heat gun to the tank to loosen the adhesive. Anybody do this before?
Old 07-01-2008, 11:53 AM
oldgeezer's Avatar
oldgeezer
oldgeezer is offline
Default RE: Tank emblem
Heat it up with a hair dryer then spray WD40 on the tape and it will start loosening.&nbsp\\; Once the emblem is off, you can use WD40 to remove the tape residue.
Old 07-01-2008, 12:30 PM
128auto's Avatar
128auto
128auto is offline
Same as oldgeezer
I found hair dryer and WD-40 works the best.
Old 07-01-2008, 12:51 PM
Harley_Dude's Avatar
Harley_Dude
Harley_Dude is offline
20 lbs fishing line and some patience.
Old 07-01-2008, 03:07 PM
crazytrain1's Avatar
crazytrain1
crazytrain1 is offline
just did mine last weekend and it turned out great...spray it with wd40 and put some heat on it with a blow dryer.....i tried dental floss but it broke fast from the heat and theading it back and forth....try fishing line and go slow...bought some adhesive remover from walmart to get the extra residue off....
Old 07-01-2008, 03:23 PM
Clammy's Avatar
Clammy
Clammy is offline
Received 1,767 Likes on 776 Posts
If you can find Goo Gone, use that. It just dissolves the glue, but doesn't hurt the paint.
Cheers!
[sm=icon_rock.gif][sm=icon_rock.gif][sm=icon_rock.gif]
Old 07-02-2008, 12:53 AM
DaFrankster's Avatar
DaFrankster
DaFrankster is offline
3-M Adhesive remover......buy it at autoparts stores....(specialty paint shops stock it as well.....the ones who sell paint to auto-body shops)
&nbsp\\;
Works like a charm.&nbsp\\; Kills the adhesive and not your paint......absolutely safe..........used it on mine to remove the 05 Deluxe emblems.
&nbsp\\;
Cheers,
&nbsp\\;
Old 07-02-2008, 12:43 PM
soundlogic's Avatar
soundlogic
soundlogic is offline
Where do I get the right kind of double sided sticky tape to put new?old badges on?
I want it ot have the black foam on it.
Thanks\\; Tim
Old 07-02-2008, 01:51 PM
ebeattie's Avatar
ebeattie
ebeattie is offline
Dunno about the foam. but to get it off, hair dryer and fishing line as others have stated. I have found that, in my professional opinion, that Acrysol Body Solvent is the best. Hands down gets EVERYTHING off and its paint safe. Does remove wax REALLY well so after you clean the tank and get the new emblem on, you'll want to get a good coat of wax on her.
Old 07-03-2008, 06:38 AM
JoeFLHX's Avatar
JoeFLHX
JoeFLHX is offline
Try body shop supplier or 3M products.
Quick Reply: Tank emblem
