Synthetic Oil For Primary
Old 07-23-2008, 01:35 AM
third_left_eye's Avatar
third_left_eye
third_left_eye is offline
Default Synthetic Oil For Primary
I know it's probably been asked a few times, but what is a good synthetic oil to put in your primary. I'm thinking of putting Mobil 1 V-Twin 20W-50 in the engine, I'm just not sure about the primary. I've heard some rumours of synthetic oils causing clutches to slip, any truth to this. Anyone have any suggetions?
Old 07-23-2008, 02:13 AM
Other Sheep's Avatar
Other Sheep
Other Sheep is offline
Default RE: Synthetic Oil For Primary
I used Mobil 1 synthetic but switched to a regular motor oil, 30w and the clutch seems to have a better feel. Many say you are just wasting money using a syn in the primary, especially for the clutch. Some have said they felt slipping with a syn. Harley has a primary oil they recommend, not a syn.
Old 07-23-2008, 02:59 AM
wallyn's Avatar
wallyn
wallyn is offline
Harley recommends their syn3 for the primary as well as their other holes. I run regular dino for the primary and mobil 1 for then engine and trans.
Old 07-23-2008, 04:28 AM
RockerMike's Avatar
RockerMike
RockerMike is offline
I am switching from Syn3 to Redline MTL in the primary. Also going to switch to Redline Shockproof Heavy in the Trans. Will let you know if any different.
Old 07-23-2008, 05:21 AM
Chief101's Avatar
Chief101
Chief101 is offline
Personally..........I didnt like the feel of the clutch when I tried synthetic in the primary. I switched back to HD Formula + and like it much better.
Old 07-23-2008, 05:23 AM
Stevenacnj's Avatar
Stevenacnj
Stevenacnj is offline
I put Redline MTL in the primary &amp\\; Redline Heavy Shockproof in the tranny at the beginning of the summer. Clutch feel is great, runs quiet, &amp\\; clunk noise when shifting was reeduced.&nbsp\\;
&nbsp\\;
FYI - can get the Redline products here:
&nbsp\\;
http://www.racerpartswholesale.com/category/Oils_And_Brake_Fluid
Old 07-23-2008, 07:04 AM
In Memoriam Citoriplus's Avatar
In Memoriam Citoriplus is offline
May our Moderator Rest in Peace
I have used Mobil 1 20/50 for V-Twins in the engine and primary and Mobile 1 75/90 in the tranny with no noticable ill effects. But it does run cooler and shift smoother.
Old 07-23-2008, 07:06 AM
jimmers1817's Avatar
jimmers1817
jimmers1817 is offline
I've heard those rumors also.&nbsp\\; Haven't read of any good reason to switch from Formula+ for primary.&nbsp\\; Others holes, yes.&nbsp\\; Primary NO.
Old 07-23-2008, 10:11 AM
Other Sheep
ORIGINAL: wallyn
They did when it first came out. They dont anymore.
Old 07-23-2008, 10:18 AM
PoorBoy's Avatar
PoorBoy
PoorBoy is offline
I have synthetics in all three holes. Been that way for me since 500 miles on the odometer.&nbsp\\;Now, over 13,000 miles and no issues or complaints.
&nbsp\\;
Previously- AMSOil in all three holes, now (last two oil changes), Mobil-1 V-Twin in engine &amp\\; primary, a stronger Mobil-1 for the tranny.
&nbsp\\;
BTW: My dealer is still pushing Syn3 for all three holes. (but my bike has never been to the dealer's service department).
Quick Reply: Synthetic Oil For Primary
