"DYNO" Numbers For SOFTAILS
  #1401
Old 12-23-2018, 10:44 AM
akdeadhead's Avatar
akdeadhead
akdeadhead is offline
2017 FLSS: 117 Stage IV. Vance and Hines Big Radius. PS Tunes etc.
The following 2 users liked this post by akdeadhead:
Paintslinger16 (02-03-2019), Richvw (02-02-2019)
  #1402
Old 01-29-2019, 06:53 PM
fatboy42's Avatar
fatboy42
fatboy42 is offline
6th Gear
watching a 2016 bruce concert as im reading you quote, nice.. its a death trap, its a suicide rap.
  #1403
Old 02-02-2019, 08:28 PM
oldtoad's Avatar
oldtoad
oldtoad is offline
Default 2005 Deluxe
Bike had stock motor, stock pipes. Around 38K miles. Had Fuel Moto 98" Big Bore kit installed (link) using Superttrap Supermeg 2/1 pipes with 19 discs.
  #1404
Old 02-11-2019, 05:11 PM
basketcase1119's Avatar
basketcase1119
basketcase1119 is offline
I did the Fuel Moto 107” kit on my 2012 Slim. I took it to Wolf Grasser w/Mutant Motors in Baytown Tx for the build & dyno.
The kit comes with CP Carrillo pistons & Woods lifters. I chose the Woods 555 cams & the compression is 10.25:1. I haven’t done any headwork yet, but already had an S&S Stealth AC & Vance & Hines Short Shots in there.
The Short Shots are horrible, and I’ll be swapping to a D&D Bobcat when I have the $ for Wolf to rework the heads. It was tuned with a PCV. Really wish I had a Power Vision.
I’ll have to get Wolf to send me a copy of the dyno sheet, but the baseline was right at 73HP & 84FT/LB. The final numbers were a fraction over 100HP & 119FT/LB.
  #1405
Old 02-16-2019, 06:54 PM
NAPRA's Avatar
NAPRA
NAPRA is offline
Rinehart exhaust, Cobra intake and SE tuner:
  #1406
Old 03-02-2019, 09:07 PM
Jake flstfb's Avatar
Jake flstfb
Jake flstfb is offline
2014 Fat Boy Lo, 110 S&S kit, S&S 585 cams, ported heads, 50 mm Screaming Eagle throttle body, Heavy Breather, D&D Fat Cat.
  #1407
Old 03-27-2019, 05:55 PM
Steve2002's Avatar
Steve2002
Steve2002 is offline
Default MY DUECE 2002 88ci
  #1408
Old 07-16-2019, 05:10 PM
Z'Stein's Avatar
Z'Stein
Z'Stein is offline
Default New Dyno Numbers for my Slim S
I recently pull the stock SE255 cams and replaced them with the SE259e cams, and bumped the compression up a point. It picked horsepower and torque. The horsepower really jumped up (from 95 to 112 plus) from the original dyno pulls. Here's a picture of the bike and the best two pulls.
  #1409
Old 11-18-2019, 03:50 AM
HarleyViking's Avatar
HarleyViking
HarleyViking is offline
Default Fatboy 2002 EFI
SE 203 Cams
SE A/C with K&N filter
V&H 2 into 1 Pro pipe with quiet baffle
Tuned with Power Vision
I think the rest is stock but haven't checked if it's still a 88 and not a 95 or so?!
WOT shows 97.6ft-lbs @ 3,418rpm and 76.1hp @ 5,413rpm but the real benefit of the tune was at cruising when the bike was running waaaay to lean as you can see in the second picture.
  #1410
Old 11-20-2019, 09:21 AM
Breakout110's Avatar
Breakout110
Breakout110 is offline
Default 144hp/148tq
Revolution 117, 11.3:1 CR, 640 gear drive cams, HPI 58mm, Ported Heads/Big Valves.
The following 2 users liked this post by Breakout110:
Madnss (01-11-2020), Z'Stein (11-20-2019)
Quick Reply: "DYNO" Numbers For SOFTAILS
