Scraping Footboards
When they scrape the sound is satisfying enough but I would like to get more sparks.
I read that adding a titanium bolt to the bottom may improve the visual. Has anyone tried this?
McMaster-Carr
Part Number: 9101K211 $28.58 Each
Material
Ultra Corrosion-Resistant Pure Titanium (Grade 2)
Shape
Sheets, Bars, and Strips
Thickness
.375"
Thickness Tolerance
+0.055", -0.010"
Length
12"
Length Tolerance
+1/8"
Width
3/8"
Width Tolerance
+1/8"
Straightness Tolerance
Not Rated
Finish
Unpolished (Mill)
Hardness
Rockwell B80
Yield Strength
40,000 psi
Condition/Temper
Hot Rolled Condition/Annealed Temper
Specifications Met
American Society for Testing and Materials (ASTM)
ASTM Specification
ASTM B265
WARNING
Hardness and yield strength are not guaranteed and are intended only as a basis for comparison.
I scraped mine for the first time a couple of days ago. That was at slow speed turning onto an on ramp. Guess I don't ride that hard yet. Are you scraping at speed through curves or at low speeds similar to what I did? I've read comments from others saying the floorboards will pivot up so you don't have to worry, but mine seem really stiff. Takes alot of effort to raise them by hand and the same to push them back down again. Does anyone loosen the bolts a little so they pivot more freely?
