Start problems
Old Oct 11, 2008 | 06:57 PM
TIPN8R's Avatar
TIPN8R
Default Start problems
I'm at a loss. Starter whines but doesn't engage. Tapped the starter a few times to no avail. Trying to determine what is wrong before pulling off Primary cover to see what is up.....any suggestions?
Old Oct 12, 2008 | 08:03 AM
TIPN8R's Avatar
TIPN8R
TTT anyone?
Old Oct 12, 2008 | 09:55 AM
hotrod351's Avatar
hotrod351
sounds like the bendix. mine would do that once in a while. had to take it out and replace the bendix drive, thats the part that makes the starter drive jump out and engage the clutch gear to turn it over. they sell the drives on ebay. i have a open bdl belt drive so it wasnt that bad to do but you have a enclosed so your going to be taking the primary off. its a pain but just think when you fix it, youll be good to go for a long time.
Old Oct 12, 2008 | 10:29 AM
agapsdiver's Avatar
agapsdiver
Sounds like you need a new battery.
You might have 12.5volts..... but not enough umpgh
(my tech term) to start. I've had several batteries that
had plenty of volts.. but when the dealer hooked up to
their batt. checker they did not have the cranking POWER.
Old Oct 12, 2008 | 04:25 PM
TIPN8R's Avatar
TIPN8R
Thanks guys but found the problem. Took off the primary case to find the jack screw hanging out. Weird thing too. There was plenty of loctite on the threads and the tab was bent over the hex.....weird, but either way it's all fixed and i'm out the door!
jster171
Aug 4, 2015 04:17 PM
Dyna7
EVO
27
Jul 1, 2012 06:56 PM
Spades
Shovelhead
May 10, 2010 10:26 AM
cmiller03
May 12, 2008 11:11 AM
Surfit
Oct 1, 2006 10:14 AM
