It's yours, put it how you like it. Did you do the engine build? If so, how did it turn out?
had problems(never got them) getting pistons in on my time off work , wich may have been a good thing now just need pistons and time again. I am tring to sell a pistol so I can get more money for everything and get heads gone over and milled to 83-84 and a set of good 9.25 pistons.
havent took any lately nor have any on this comp. will take some next weekend havent done much with it its basically a completely stock red 83xlh with cv carb and stock pipes without crosovers
A/C Direction indiferent to air flow due to negative pressure from cylinders suck ing air in. At high speeds air pressure will be decreased on the back side of a vertical intake surface due to airflow around that surface.
Looks are in the eyes of the beholder.
